Noises coming from under dashboard
2007 CADILLAC CTS
74,066 MILES
JMELO26
My 2007 cts makes noises under the dashboard when you put the car in on position and also while the car running; clicking noise,and gorgling sound coming from driver's side of the car's dashboard. If anyone can help me I would gladly appreciate it.
Thanks
May 22, 2013 at 10:18 PM
SINBAD271
  • 169 POSTS
Check you coolant level at the radiator , may be low, if it is conduct a coolant pressure test, there is a leak in the system . The gurggle sound may be coming from your heater core which uses coolant . This can be mostly heard at first start up, or after a long cool down period. Hope this will help.
May 23, 2013 at 5:51 AM
JMELO26
Thanks sinbad, my coolant bottle is full but I don't know how to check coolant level at radiator because I don't have a radiator cap. How do I perform a coolant pressure test?
Thanks
May 23, 2013 at 7:27 AM
SINBAD271
  • 169 POSTS
I believe your over flow bottle has the cap on it ,it may take a special adapter to connect the pressure test tool. You may want to take it to a repair facility and have a coolant diag done. Tell them your symptom your haveing it may cost one hour diag time. But it is very accurate and will save you the possibility of blowing a head gasket which lead to more money . A facility like pepboys can be very helpful . Or some place you feel comfortable with.
May 23, 2013 at 10:10 AM
SINBAD271
  • 169 POSTS
Have it check for an air pocket there is a port to allow coolant system to be bled at usually around hose housing on top of intake manifold. Your welcome.
May 23, 2013 at 10:14 AM
