whirling noise under hood?
2019 TOYOTA HIGHLANDER
93,400 MILES • 6 CYL • 4WD • AUTOMATIC
SHANNA91
  • 4 POSTS
Hearing whirling noise coming from under hood
Mar 3, 2026 at 8:40 AM
Hello, I can help you, It sounds like it can be a serpentine belt, but if you upload a short video in your response of the problem, so I can see what's going on for sure. Here is a guide to show causes of whirling noises and how to fix them in the meantime.
https://www.2carpros.com/articles/whirring-sound
Please go over this guide and get back to us. Ken
Mar 4, 2026 at 7:38 AM
SHANNA91
  • 4 POSTS
Hi, thanks!
Mar 4, 2026 at 7:39 AM
Thanks for the video, can you open the hood and get an idea of where the noise is coming from? Please upload a video of the origan of the noise, that way we can pin point it. Also, is this car a hybrid? Does the noise change when you put the car in gear? Ken
Mar 4, 2026 at 7:42 AM
SHANNA91
  • 4 POSTS
Not a hybrid, it goes away after 5 minutes of warming up after cold start in the morning!
Mar 4, 2026 at 7:44 AM
Wow, that is a good one, to me it sounds like a vacuum leak but it still might be the serpentine belt, can you tell if the noise is coming from the belt area? If you have a spray bottle with water you can spray it onto the belt while the engine is running and if the noise changes replace the belt, thank again for the video. Here is a video to show you how to check for a vacuum leak.
https://www.youtube.com/watch?v=LRKWV4Are5c
Let us know what you find.
Mar 4, 2026 at 8:00 AM
