Noise while coasting or braking at low speed?
2015 FORD F-150
197,000 MILES • 3.5L • V6 • TURBO • 4WD • AUTOMATIC
CONNOR ANDERSON
So, all of my wheel bearings are new. New calipers rotors and cv axles but when I'm coasting to a stop or braking at low speed there is a slight scraping or grinding noise. I was concerned it was the transmission but when i accelerated the trans shifted and down shifted smoothly.
Sep 20, 2024 at 12:23 PM
It is possible that the brake pads used for replacement are causing the sound you hear. Pads are manufactured using different components. Some can make noise.
When you are coasting at low speeds and hear it, does the sound change in volume or pitch when the brakes are applied?
Sep 20, 2024 at 8:34 PM
CONNOR ANDERSON
No sir, It may have been too loud where i was driving to hear a change in pitch.
Sep 20, 2024 at 9:10 PM
Can you please shoot a quick video with your phone so I can hear the noise? That way I can tell for sure what's going on. It could be the parking brake shoes or one of the backing plates is touching the brake rotor. Also can you tell if it is coming from the front or rear of the truck?
Sep 21, 2024 at 10:21 AM
