Noise when turning
2012 AUDI A3
10,000 MILES • 2.0L • TURBO • 2WD • MANUAL
GAVIN
  • 4 POSTS
Hi all,
I wonder if you can advise me. when i turn my car left or right i can hear a slight humming/grinding noise at low speeds normal speeds everything is fine. I have changed new brake disks and pads and new CV joints and new front wheel bearings and hub, but still have the issue.
Aug 5, 2017 at 7:09 AM
It sounds like it could be uneven tire wear patters. Can you check out this guide and get back to us please?
Rotate the tires to fix.
https://www.2carpros.com/articles/how-car-tires-work
Aug 7, 2017 at 11:12 AM
GAVIN
  • 4 POSTS
Hi Ken, thank you very much for your message.
I have checked the tires as you have suggested and I can see that there is wear on the outside wall on the passenger tire. I am unable to swap this with a spare tire as I do not have one with my car (repair kit only). As for the drivers side the tire is brand new. do you really think that this noise/issue I am having is down to the bad tire?
Thanks,
Gavin
Aug 8, 2017 at 1:04 AM
Can you take a picture of the tire tread and upload it?
Aug 8, 2017 at 2:05 PM
GAVIN
  • 4 POSTS
Hi Ken,
Apologies in late responding to you. As i have not been able to see where this issue is as was not sure if its dangerious i have booked it in today with an AUDI/VW specialist and after speaking with them not long ago they have informed me that the tyre on the drivers side has been incorrectly fitted (dirrectional wrong way round) . They have advised me to go back to the place that fitted the tyre and get it corrected. Is this a possability why i am having this noise ? due to the incorrect fitting of a tyre ( directional way)
Aug 16, 2017 at 6:36 AM
O ya, that can do it. Please let me know what happens.
Aug 16, 2017 at 10:50 AM
