Noise, rattling that sounds like it is coming from engine
2004 NISSAN MAXIMA
143,000 MILES • 3.5L • 6 CYL • FWD • AUTOMATIC
DOUDA
After I get my oil changed, about 2000 miles or 2 months later my car starts making a rattling noise that sounds like it is coming from the engine. As soon as I go in to get my oil changed it stops and the car sounds great for another 2 months.
May 17, 2014 at 7:15 PM
CARADIODOC
  • 34,306 POSTS
That isn't much to go on but it would appear you're running the engine out of oil. Do you check the level at least once a week? It's normal for all engines to use a little oil between oil changes, but if it gets too low you risk destroying the engine. They can survive being one quart low, and you might get away with two quarts low for a little while, but that will accelerate wear inside the engine.
If you don't know how to check the oil level, have the mechanic show you how at your next oil change. It must be done with the engine not running. You'd rather add a quart of oil if necessary than pay to have the engine replaced or rebuilt.
Also mention the excessive oil usage at your next oil change. They'll look for signs of a leak.
May 17, 2014 at 9:00 PM
