Ringing noise above 20 mph but stops below
2009 CHEVROLET SILVERADO
200,000 MILES • 6.0L • V8 • 4WD • AUTOMATIC
AUSTIN0908
The faster I go sometimes it will stop then start back up. I've replaced both CV axles in front end and wheel hubs and still doing it. I just replaced u-joints.
Oct 19, 2019 at 9:05 PM
Welcome to 2CarPros.
Is there anything you can do that stops it? For example, if you apply the brakes does it stop? Also, is there any change in the pitch when making turns?
Check to make sure there isn't a brake sensor touching the rotor as well as if one of the backing plates behind the rotor.
Oct 19, 2019 at 9:54 PM
