Yes, I have good oil pressure and it has not overheated. But a closer look underneath while someone pushed on the gas it is coming from the transmission pan. Yes, I have learned my lesson about stop leak now. Could it have plugged up the transmission filter perhaps would that make a noise?
Nov 5, 2018 at 7:26 AM
CERTIFIED EXPERT
Okay, you would need to replace the pan gasket. I will attach a procedure for you.
That will get most of the sealer out of the system.
Thank you very much, but did I mention the leak was up where the fluid goes into the cooling system?
Nov 5, 2018 at 9:30 AM
LADONNA AVERA
MEMBER
If it matters.
CERTIFIED EXPERT
Yes, but you said you used stop leak and it stopped?
Can you post a picture of what you see?
Nov 5, 2018 at 9:37 AM
LADONNA AVERA
MEMBER
I am so sorry I did not have my phone on me. I was out working on the truck, there is that really know where to get a picture it is right up by the radiator underneath the radiator hose where the transmission fluid goes into the cooling system. It is still knocking. I do not know I got to get somebody to look at it and tell me exactly where is coming from now. Thank you very much for answering and I do really appreciate it.
Nov 5, 2018 at 4:04 PM
CERTIFIED EXPERT
No problem.
Yes, get someone to look at it. A leak will not cause a knock. That is a separate issue.
