what is the proper for the inlet door actuator or is this the proper name thx its the one mounted on the firewall passenger side
May 21, 2023 at 9:56 AM
CERTIFIED EXPERT
I believe you are referring to the recirculation door actuator. I attached a pic below that identifies all components related to the HVAC system. See if you can identify the component you are referring to. I suspect it is the recirculation door actuator.
