This could be the case as when you are turning the wheel to a sharp turn the caliper can slide on the caliper pins and put pressure on the pads.
Here is a guide that will help with this as there could be other causes:
https://www.2carpros.com/articles/vehicle-grinding-noise
If the brake pads are making this noise then they most likely need to be replaced.
Here is a guide that will help with this as well:
Below you will find the detail from the manual on how to do this as well.
I would suggest replacing the pads if they are low and then retest to see if the noise is still there.
Let me know if you have questions. Thanks
Feb 26, 2021 at 1:52 PM
