I have been working on a no start over 6 months. Checked and changed everything possible except the ECU. I only have 2.8v power to injectors and no power no pulse to crankshaft pulse sensor. I discovered that if I remove one of the power connector plugs to the ECU then I have power to injectors and crankshaft sensor. All the wires in this connector tested to be 10v, 11v, 12v and grounds. I'm confused. If when this connector is disconnected and the power flows normal mean that the ECU is not at fault? Please give me some understanding of what might be happening here. Thanks
Jul 28, 2019 at 6:44 AM
