Had no turn signals, found blown fuse. Changed, backed out and heard fuse blow. Hazards and turn signal share same relay but not power, hazard still works. Changed relay anyway, fuse blew. Checked light assembly plus wiring/Changed light bulbs, fuse blew. Checked condition of rev sw on transmission, cleaned with electric contact cleaner, fuse blew. Chg'd rev sw on transmission, fuse blew. I've been backing out in neutral since I'm on a slope then select drive to keep from blowing a fuse. Next step was to pull back-up lights out and ck rev but noticed detent for neutral was slight off. I got (N) but next detent (R) still showed (N) and I got reverse without blowing a fuse! Eases handle into next detent, (R) lit-up and fuse blew. I believe this was the case even before the rev sw was changed, just didn't catch it.
May 20, 2019 at 9:15 PM
