No turn signals but both light up solid when i press the brake pedal
1995 CHEVROLET S-10
1,410,000,000 MILES • 0.7L • 6 CYL • 2WD • MANUAL
JENNIE EWING
MEMBER
1 POST
FOLLOW
They changed the steering column, but my turn single-layer will not work at all until you push the brake pedal then they stay on solid.
Jan 19, 2017 at 1:08 AM
HMAC300
CERTIFIED EXPERT
if you mean your turn signal will not work check bulbs and then take back and tell the people that installed it as they probably have wires hooked up wrong.
