No tail lights or dash lights
1999 CHEVROLET VENTURE
218,839 MILES
JUAKI MCCANTS
  • 4 POSTS
I replaced light switch, still no lights. I keep getting the bell sound like lights are on. all other lights work even the sensor turns on front daytime lights, but not the taillight she or dash. Where can I check for bad or breakin ground wire?
Dec 16, 2016 at 3:36 AM
HMAC300
  • 48,601 POSTS
the ground for dash lights is on right hand side of dash near heat vent, but this may be a DRL module problem for both. you can check the relay in picture, but a mechanic will have to scan for codes for DRL module problem.
Dec 16, 2016 at 5:49 AM
JUAKI MCCANTS
  • 4 POSTS
Where can I locate that drl module at?
Dec 18, 2016 at 6:26 AM
HMAC300
  • 48,601 POSTS
behind dash right of steering column we have no pics for this.
Dec 18, 2016 at 8:03 AM
JUAKI MCCANTS
  • 4 POSTS
Is it something I can do myself
Dec 18, 2016 at 11:34 AM
JUAKI MCCANTS
  • 4 POSTS
I was messing around checking out the fuses the dinging sound went away then when I drove car open up door it returned now it is gone agin I also put back the original switch
Dec 18, 2016 at 11:36 AM
HMAC300
  • 48,601 POSTS
ya but if your lights still aren't working then it has to be scanned if they started to work then its' a short in wiring and start looking in trunk
Dec 18, 2016 at 1:23 PM
