Hello, being as my struts on the car listed above have no adjustment to correct right side tire leaning inward at the top. Does it make any sense to buy a new strut to replace the original strut? Front end alignment cannot be done correctly until this is fixed. Either the Tech didn't take time to fix this problem when alignment was done, or he was too lazy. I guess it's up to me to try and correct the problem. My understanding is the bottom mounting hole can be drilled to allow for some extra movement for alignment. I need to know if there is a special bolt to replace the original bolt after the hole is made bigger. I also need to know if the hole should be drilled sideways per the mounting holes or vertical up and down. How much bigger should I make the hole? Or I looked at new struts here's some of the spec's.5.91 Damper Travel and Damping type. Not adjustable. What type of drill bit is best used? Thanks. JC
May 31, 2023 at 12:56 PM
