When I crank the engine, it will not start. Added fuel, won't start and checked for spark, no spark at number one cylinder.
I looked for trouble codes, PO 320 and PO 401. I noticed that the check engine light does not come on when key is on and checked crankshaft p. sensor for voltage. it is located on the side of crankshaft pulley with 2 wires . with key on, neither wire has voltage. tested them with volt meter on ohm tester. Can you give me direction?
Aug 14, 2019 at 3:07 PM
