Have a the vehicle listed above with a 304, 3 Speed-T-150, Dana 20 transfer case. Engine, transmission, transfer case professionally rebuilt. Electrical replaced with kit from Centech. This has been a labor of love project since 2009. First symptom was while driving in the open at highway speeds (forty five to fifty mph), everything was operating as normal. Come to a light or stop sign the motor would spit/sputter or shut off. Would start right up, but had to ride the clutch to get out of traffic as there was just zero power under load. This has happened several times now. I have it in the garage and hen peck at trouble shooting but have just run out motivation at this point.
I know I am getting air and gas, I can see the gas going in the carburetor, and smell it as well. I have followed the power from firewall to ignition module to distributor and to coil (input and outputs) and ballast resistor .
I have replaced the cap and rotor (with the Team Rush upgrade using the F-350 cap and rotor) replaced ignition module, coil, spark plugs and wires. Only thing left in the life cycle is the ignition switch and ballast resistor.
The engine is a standard 304, Holley 650CFM 4 barrel carburetor, headman headers.
Jul 22, 2018 at 5:36 AM
