Will not stay running after replacing the turn signal switch and clock spring?
2007 DODGE CHARGER
15,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
363BASS
Replaced broken turn signal switch and clock spring. I reconnected the battery; the car cranked and started and shut off three times and nothing after that. no bus came up and red-light alarm came on dash.
May 31, 2023 at 10:59 AM
It sounds like you have wrong/defective parts but to be sure let's do a CAN scan to see which codes come up, you can get a CAN scanner (Controller Area Network) which will work on most cars from Amazon.
Here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
and
https://www.2carpros.com/articles/can-scan-controller-area-network-easy
Here is one for about $99.00 if you need it:
https://amzn.to/3ZixY4v
Please go over these guides and get back to us.
Jun 1, 2023 at 2:53 PM
