The car was starting right up every time then replaced the power steering pump. after that had to bleed power steering car goes into limp mode and won't start, but with a jump it would and alternator is good. So got a new battery and installed it car starts still in limp mode keeps going in and out of limp mode. then next morning battery was drained to battery back to have it charged. checked all fuses then put battery back in and started up then next morning battery dead again. so got a jump and this time no crank no start. So I tried to test battery and it had 12v before it was showing something was pulling 3.92 from my battery this time it's not so I push on brake pedal while key in and push start put in second position and I keep pumping on the brake finally car starts. Then I can't get it to stay running it just cuts off every light on the dash is lit up!
Apr 26, 2019 at 8:54 PM
