Welcome back:
No problem. What I need you to do is this. You will need to remove the battery and take it to a parts store to see if they can recharge it and check it for performance. If you take it to a nationally recognized parts store, most likely it will be done for free. However, before you remove the battery, check the battery terminals to make sure they are clean and tight.
If nothing at all works on the vehicle, either the battery is totally dead or you lose connection to the battery. First, here is a link that shows how to check the battery terminals and to clean them:
If that doesn't help, we need to remove the battery and replace a battery:
https://www.2carpros.com/articles/how-to-replace-a-car-battery
We need to start with this. Without being able to at least start the vehicle, we can't check the alternator. Also, the entire problem could be related to a battery connection issue or just a dead battery.
I would like to know if the lights and other things work when you try to jump start the vehicle.
Do this and let me know if I can help.
Jul 29, 2020 at 5:48 PM
(Merged)
