no start, no communication to OBD2, cooling fans on, ECU offline?
2010 NISSAN PATHFINDER
85,000 MILES • 4.0L • V6 • 4WD • AUTOMATIC
ALI MAHMOUD
The original harness was cut up and chewed up from previous owner testing and from rat damage. I replaced the entire harness and the IPDM from a junkyard salvage. I get power and grounds to all connections in the ECU ports except port 119 and 120 which turn on the ECU. I'm getting 0.30volts not exactly 0 volts. Is this a short? Port 109 is getting battery voltage from the ignition switch which I traced back.
I checked continuity from several wires going into the IPDM and I'm getting a continuity beep from a lot of wiring. The headlight, fog light, ac compressor, wipers, all are showing continuity to ground. What is going on here? Do they share a same power source that is shorting?
I am lost with this and frustrated after chasing wires for several hours and rereading power diagrams. Any help is needed.
Oct 14, 2025 at 8:56 PM
ALI MAHMOUD
Checked the OBD2 port, DLC pin # 6 and # 14 and got 120ohm resistance. Is this showing a short to the sensors ?
Oct 14, 2025 at 9:04 PM
I would double check all of the wiring harness grounds and fuses in the fuse panels,(key on) then I would run the codes to see which system is having and issue. Please go over this guide to help:
and
CAN SCAN - https://youtu.be/u-4syLc-ifQ
Does the car not crank over? not run? Please give me more information.
Oct 15, 2025 at 9:40 AM
ALI MAHMOUD
Car will crank for days no problem but ignition and fuel is cut due to no power to ECU. ECU does not get power on pin 119 and 120 which is key on, power on. I get 0.30volts when key is on and 0 volts when key is off. Pin 109 gets power from ignition fine.
ODBII pin #6 and #14 has 120ohm resistance. Short or open in resistance somewhere?
No communication from the OBDII port.
Oct 15, 2025 at 10:28 AM
The port 119 and 120 get power from the ECM power relay and fuse #53 in side the IPDM. With the key on I would check the green wire port number 3 on the IPDM which should have 12 volts. Please let me know.
Oct 16, 2025 at 9:55 AM
