drain on battery
1998 FORD EXPEDITION
207,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
NCIRINO
Car will not start. Have replaced starter, battery, and alternator all within the last year. Something keeps draining on the battery to make for not enough voltage to start. Car will start when jumped.
Aug 27, 2018 at 8:01 PM
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
That best I can advise is if you know someone with automotive/electrical knowledge and a 12 volts test light to do the following. Using the test light with engine not running disconnect the negative battery terminal and install the test light in between the battery terminal and the battery. Start to disconnect the fuses in the under hood junction box one at a time. When the light dims/goes off on the tester you will the know what circuit is drawing power/draining your battery. With me so far? We can go from there. Hope this helps and thanks for using 2CarPros.
Danny-
Aug 27, 2018 at 8:13 PM
NCIRINO
Pulled all the fuses while using the test light as instructed. No fuse caused the light to dim or turn off. Could it have anything to do with the ignition? Where is a good place to start looking for answers?
Aug 29, 2018 at 9:09 AM
Lets look at the seat and mirror switches to see if any are stuck this will cause the battery to drain down. Here is a guide that mentions other obvious problems:
https://www.2carpros.com/articles/car-battery-dead-overnight
Aug 31, 2018 at 2:43 PM
