Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Dodge
Neon
Engine
Throttle Body
Replace/Remove
No start backfire from throttle body
1999 DODGE NEON
120,000 MILES • 2.0L • 4 CYL • FWD • AUTOMATIC
SHARANETTAP1
MEMBER
FOLLOW
Replaced cylinder and timing belt. crank engine over no start and backfire from throttle body.
Sep 12, 2016 at 9:05 PM
SATURNTECH9
CERTIFIED EXPERT
Have you rechecked to make sure the engine is timed correctly? Sounds like it is not timed correctly.
Sep 12, 2016 at 11:14 PM
SHARANETTAP1
MEMBER
Rechecked timing checked fuel pressure got spark got injector pulse.
Sep 13, 2016 at 6:59 AM
SATURNTECH9
CERTIFIED EXPERT
So did the belt break or jump time is that the reason why you changed it? or did you you just change it for maintenance?
Sep 13, 2016 at 8:00 AM
SHARANETTAP1
MEMBER
ran hot got head reconditioned and changed timing belt.
Sep 13, 2016 at 9:16 AM
SATURNTECH9
CERTIFIED EXPERT
Is it setting any codes? It really sounds like its out of time though from the back fire through the throttle body.
Sep 13, 2016 at 4:26 PM
