Fiancé's car has had a rough idle for quite some time, but here recently it has gotten worse, it has gotten to the point where if she has stopped for too long it will stall out and shut off. So, I thought it was the IAC valve and I replaced the valve after replacing the car will crank but will not turn over. so, I put the old IAC valve back on the car and still no start, but it will crank like no tomorrow. also, it does have a fairly new alternator, a brand new, starter a brand new, battery brand new serpentine belt, and tensioner pulley. I did check fuel pressure and it is getting at accurate fuel to the fuel rails and I did replace the spark plugs and wires about a year ago. It does have a check engine light on and I'm working on getting the codes but the light has been on before this problem arose.
Oct 14, 2021 at 11:14 AM
