No start after replacing spark plugs, wires, distributor, cap and rotor
1993 TOYOTA PICKUP
230,000 MILES • 3.0L • V6 • 4WD • MANUAL
JOEBBAD
Truck was running and starting fine. I changed spark plugs and wires distributor cap and rotor truck won't start . I pulled a spark plugs wire and used old plug and I have good spark . I jumped the fuel pump and it's running. Haven't touched anything else can't figure it out. Please help.
May 1, 2021 at 9:54 AM
JOEBBAD
I. tried spraying some carburetor cleaner in intake because still have strong spark and it doesn't even effect it . The rotor is turning if it wasn't I would think it was timing belt that's the way it sounds like turn over.
May 1, 2021 at 9:40 PM
Is it possible for you to record it cranking and upload it for me to hear? The idea that you have spark and fuel (carburetor cleaner) and it doesn't start sounds like a timing issue or a sudden compression issue.
Are you sure the wires were replaced to the correct cylinders?
May 1, 2021 at 11:19 PM
JOEBBAD
I will try to record for you.
May 4, 2021 at 1:08 AM
Hi Joe,
It sounds like a plan. Also, if you can let me know what color the spark was when trying to start it, that may help as well. You want the spark to be a snapping blue color. If it is orange or white, it may be too weak to start the engine.
May 4, 2021 at 6:56 PM
