The car has a 3.4 V6. It has been sitting for about 6 years. I replaced the fuel pump and filter and gas. It is getting about 45 PSI on pressure gauge as i turn the ignition on and while cranking engine it tries to start. If i press the pedal just a little it stops trying to start. FPR doesn't have a leak into vacuum line If I just charge the system, no start it will leak down to about 30 psi in 10 minutes just sitting and stays there.
Any help will be appreciated.
May 14, 2023 at 4:06 PM
