Shut off while driving, found timing belt partially cut through outer cover and after getting to the timing belt found with no lugs at all, tensioner destroyed. Replaced all and set timing and no start, a couple puffs when first turn the key but nothing. No codes, obd2 seems to be communicating okay. New crank and cam sensor and coil pack. Shaped auto shut down relay with low fan relay with no change.
Sep 15, 2024 at 4:52 PM
