If they both came on at the same time, I suspect it is either a stretched chain issue, a chain tensioner, or a chain jumped time.
There are three timing chains on this engine, a primary, a left secondary, and a right secondary. See pics below.
Here is the odd thing, I question if it is a secondary chain because each bank (or side of the engine) has a related code. So, my first suspect is the primary chain either lost tension or is a tooth off.
On the other hand, is the engine oil clean and full? There could be a hydraulic issue with the variable valve timing, but both sides failing at the same time is odd. Ugh. This won't be an easy one. LOL
I suspect the timing chain cover needs to be removed for inspection of the chains, tensioners, and correct timing.
Let me know your thoughts.
See pics below.
Oct 24, 2023 at 7:17 PM
