No start
2003 BMW 745
311,000 MILES • 4.4L • V8 • 2WD • AUTOMATIC
MS.CAIN3121
All lights and windows work but car will not let you change settings or play music. car was working fine one day the next day it was cold and the car would not start. I got a boost it worked then had another cold day it would not start. changed battery car still would not start. changed starter and car is still not starting. new starter sounds like it turning over though.
Nov 23, 2017 at 4:40 PM
If the new starter is turning the engine over and it refuses to start, check to see if it will start using starting fluid. If it starts and runs a couple seconds, then the problem is fuel related. If it does not start, check to see if there is spark to the plugs.
Feb 12, 2021 at 10:16 AM
RENEE L
  • 1,260 POSTS
Hi MS.CAIN3121,
I am sending you a link to an informative article from this site that features written step by step instructions and a video on what to check when your cranks but will not start.
I hope this helps you and if you need further assistance please return to the site we are here to help.
Thank you for visiting 2CarPros and have a wonderful rest of your day!
Kindest regards,
Renee
Admin
