The engine will not crank but if you bypass the starter, it will turn over but not start?
2009 FORD FOCUS
110,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
KREED1968
We have had this car for about five months. About a month after we bought it, we were out in it, shut it off to go in a store and it would not start back, no crank or anything. We waited about a half hour and tried again, and it started the first try. This happened about three more times with it taking longer to start back until this last time it has not started in over a week. It will not crank but if you bypass the starter, it will turn over but not start. The electric fuel pump is not kicking on, so basically nothing on the motor is working but everything on the inside comes on. We put in a new battery and checked the fuses and relays.
Aug 20, 2017 at 4:31 PM
It sounds like you have a crankshaft angle sensor that has gone bad. This will make the fuel pump stay off as well.
Here is a guide to let you know what you are in for when doing the job:
You may need to jack the car up here is a guide on that as well:
Here is how you do the job in your car.
Aug 21, 2017 at 5:26 PM
