This could be a problem with your vehicle's Crankshaft Position Sensor (CKP). This sensor provides the Power-train Control Module (PCM) a signal with where the engine is in it's 4 stroke cycle. The PCM, or "computer", uses this signal to make the spark plugs spark, and make the fuel injectors work. In the diagrams down below I have not only given you the factory guide for troubleshooting the CKP, but instructions for the removal and installation of the CKP as well, in case the tests show the CKP to be bad. Please go through these guides and get back to us with what you are able to find out.
Thanks,
Alex
2CarPros
Aug 6, 2019 at 9:31 AM
