No start
2002 HYUNDAI SANTA FE
204,000 MILES • 2.7L • V6 • 2WD • AUTOMATIC
JWH039
It threw a crankshaft position sensor code, I replaced it and now no start.
Apr 30, 2021 at 8:31 PM
This is a straight-forward job. If everything is properly connected, it should be fine. Do me a favor. Check to see if there is spark to the plugs. Here is a link that shows how that is done:
If there is no spark, you may have gotten a bad part or one of the pins in the connector may have been damaged.
I attached the directions below for removal and replacement. You can take a look through them and see if that is what was done.
Let me know. Also, let me know what code was set that led to the replacement of the CKP.
See pics below.
May 1, 2021 at 8:44 PM
