Did all these problems happen at once? I would check the brake fluid and the brake pads, but I have seen the ABS control module go out and cause this issue. For the ABS and traction control the speedometer issue will cause these warning lights to come on because they are all produced by the ABS control module. We should do a CAN scan to confirm the issue. You can get a CAN scanner (Controller Area Network) which will work on most cars from Amazon.
Here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
Here is how to change the module out in case a code comes up for it. Check out the images (below). Please let us know what happens.
Nov 1, 2024 at 12:46 PM
