No speedometer and transmission does not shift out of first gear
2002 PONTIAC GRAND PRIX
23,788 MILES • 3.8L • V6 • 2WD • AUTOMATIC
BERNADETTE MCFALL
We had the speed sensor change and it drove good for a day or two but the speedometer stop working and now it does not shift out of first.
Aug 4, 2018 at 1:32 PM
Good afternoon.
The reason the transmission will not shift is the speedometer is not sending a signal to the PCM.
The first thing I would check is the connector at the sensor. They are common for failing from either loose pins, damaged pins or burned pins.
Aug 4, 2018 at 1:58 PM
