This is my second winter with no real heat.
I discovered by turning function control to vent with maximum heat on dial I get a little heat drifting into the cab, but this is really not adequate enough especially when demisting is required on the windshield.
What I have done so far is check fuses, replaced blower motor, checked resister and replaced but think the old one is still good.Also have bought a new 4 wire pigtail and fitted. But found this to be burnt and socket has crumbled so needs replacing again.
I read your remedy on this and tried to find power with multi-meter with ignition on.
All 3 colored wires had 6 volts and the thick black ground wire had no power.
Any suggestions please?
Nov 18, 2019 at 5:21 AM
