no spark to the injectors
2000 INFINITI QX4
150,000 MILES • 3.3L • 6 CYL • 4WD • AUTOMATIC
AMY PROMAN
injectors has no spark and the fuel pump runs all the time.
Jun 20, 2017 at 12:58 AM
It sounds like you have two problems, first the fuel pump relay is stuck on and needs to be replaced and for the spark it sounds like you need a crankshaft angle sensor.
Here is a guide that will show you what you are in for when doing the job.
Here are diagrams (below) on where it is in your car.
Jun 22, 2017 at 11:09 AM
