no spark out of coil
1991 FORD E-SERIES VAN
500,000 MILES
VERN GUILD
I have power to the coil from the red and yellow wires. I replaced the coil, the plug, the ingnition modulator on the firewall and the modulator off the key under the steering column. I also replaced the coil wire and rotor and rotor cap yet i still don't have spark out of the coil.... I replaced the coil a second time,,, it ran ok until it cooled down the ran for about a minute, died and not spark again.... what can you advise about my problem
thank you for your help
May 26, 2013 at 11:19 AM
I would suspect the distributor pick up inside the distributor as the failure. measure the resistance as it should be 800-1100 ohms
May 26, 2013 at 11:27 AM
GMAN97005
  • 8 POSTS
Did you put a thin layer of thermal grease on the TFI module when you bolted it back down to the heat-sink replaced it ?
Jun 23, 2013 at 2:29 PM
