The coils all receive power from the ECCS relay, which in turn gets power to the secondary side of the relay from fuse 58. If you look at each coil, you will see a red wire. Those are the power supply. At the cylinder 3 coil, there is a splice which is what sends power to all the coils. With the key on, check for power at each of the coils' red wires.
So, if fuse 58 is faulty, that would prevent it. Also, a faulty ECCS relay can cause the issue. Or the primary side of the relay may not have power or ground. Power to the primary side is from the PCM. Once that power is sent and the ground is provided, the primary side of the relay's electromagnetic coil causes the secondary side to close and send power to the coils. Once the key is on, each coil should have 12v at the red wire. From that point, the ECM provides a ground path to each coil at specific times for fire the spark plug.
If you haven't already, check the fuse and relay I mentioned. If you have and both are good, use a test light to confirm power to and from fuse 58. If that is good, remove the ECCS relay. With the key on, two of the pins will have power. Confirm that for me. If they do, then check the relay itself.
Here is a link that explains how to check for power at the fuse and how to check a relay:
Note: fuse 58 is in the under-hood fuse box on the left side of the engine compartment. The ECCS relay is in relay box 2. See pic 3 for location and pics 1 and 2 for schematic.
Let me know what you find.
joe
See pics below.
Jul 12, 2022 at 6:47 PM
