All fuses are okay, used spark tester, no spark seen on all plugs. Initially it started, with good spark on all plug. Turned the engine off and on for a couple of times to make sure it will not stall again. On the last attempt to start, it did not fire up anymore; tested the plugs with spark tester, no more spark seen on all the plugs.
Background:
Three weeks ago, hard starting symptoms started. At time it starts after seven times, once it runs, drives smoothly.
Two weeks later, started to stall from a smooth ride, seems like no fuel.
Finally would not start. Fuel pump replaced due to no sound coming from tank when engine is on
Hard starting at first, hooked up with my van for extra power, it started.
After a couple of trouble free drive, previous hard starting started all over again, and stalls again just like before.
During the day, it starts, but will not again when engine idled for a few minutes.
Now it will not start anymore.
Observation:
My car is installed with a remote alarm with key-less entry which has not been in used for more than two years now because the remote switches are no longer working.
Before when negative battery terminal is detached and put back again, the alarm does not activate, but this time when I removed and replaced the negative terminal, the alarm sets on, and i cannot deactivate it because i do not have a working remote switch. so i unplugged all the connectors to the alarm module.
Also, when the engine is cranking, i hear an unusual sound in the tank, most likely coming from the fuel pump, which i have not heard before.
Please help, i am already having migraine figuring out how to fix this problem.
I would highly appreciate any advice.
Thank you.
Background:
Observation:
Thank you.
Apr 10, 2018 at 5:46 PM
