Welcome back:
Okay, with that in mind, I need you to check both the crankshaft sensor and the camshaft position sensor. If the camshaft sensor does not operate correctly, sequential injection is may not occur and the engine may stall or run irregularly at idle or fail to accelerate normally. I have a feeling it is one of the two items I mentioned.
Here are the directions for testing this sensor. Also, this sensor is located at near the timing belt too, so the directions are similar to the crankshaft sensor.
________________________________________
Picture 1 shows location, picture 2 is a circuit schematic, and picture 3 shows specs for harness inspection.
Let me know what you find. Also, if the check engine light is staying on, you need to scan the computer for diagnostic trouble codes. That will point us in the right direction.
_______________________________________________
May 11, 2019 at 6:41 PM
