I rebuilt my engine and transmission over the fall. Got it all together. Hit the key and started up. I heard a rubbing noise around transmission so figured a problem. Unhooked everything for transmission to take it out. Found the plate between engine and transmission got bent putting it in and was rubbing. That’s not my problem now though. In the midst of going to remove transmission my son in laws truck fuel pump went out. He didn’t have the extra money for one so I took mine out and gave him. Month goes by and I get around to putting mine all back together and put new fuel pump in. Hit the key and wouldn’t start. Tested pump and it’s good. Tested wire plug to pump and no power. Talked to couple guys that asked if I had spark. I hadn’t checked since it ran. Tonight I checked. No spark. No power to the coil. Fuel gauge doesn’t work either. Help!! I have over $5,000.00 in the motor and transmission, and about to light it up. Any help would be appreciated.
Thanks,
Dennis
Thanks,
Dennis
Apr 14, 2019 at 7:34 PM
