Ran good, drove in the garage it shut off. tried restarting started then immediately stalled. now it cranks but no sound from fuel pump, no spark at coils or wires. replaced crank sensor and cam sensor checked wiring and replaced battery cable ends. checked all fuses tried Solus scan tool had crank sensor code replaced crank and cam sensor cleared the code now no codes are coming up. have twelve volts going to ECM, but i checked the connector to the crank sensor and there is no voltage at all coming from the connector cranking or no cranking does matter no voltage. checked wiring and it looked good and ideas and is it the ECM? Also, checked ECM fuse with tester have power there checked ignition coil fuse, nothing fuse is good same with fuel fuse no power but fuse is good.
Dec 10, 2017 at 1:32 AM
