Hi guys, i changed water-pump and cambelt on the vehicle listed above 1.5.(i didn't disconnect the battery terminals before unplugging the camshaft and crankshaft sensor). Now car cranks but fuel pump not priming and i have no spark at plugs. Checked cambelt timing 8-10 times and it's good as before. Checked mai relay. It's clicking. Fuel pump relay doesn't click, even after replacing with new one. Tried jumping it to check fuel pump. Fuel pump runs when i jump the coil. Checked all the fuses under dash too. Still no luck. My OBD2 connector links to ECU but no codes shown there.
Ang help please.
Ang help please.
Oct 19, 2020 at 11:02 AM
