It sounds more like you have a wiring issue where some parts are getting power. It could be a ground issue or power or more likely corrosion in the various connectors because it has been setting that long. As much of a mess that it is I would probably start by unplugging each connection I could find, spraying in some contact cleaner and then plugging it in out a few times. That should remove any corrosion.
From there take a meter and check the power and ground connections at the SBEC. There are battery voltage, 5 volt and 8 volt feeds as shown in the pinout.
From those it will give you an idea of what you have. I would suspect corrosion may also have gotten into the SBEC and caused issues there. Also, the tech info on these is somewhat sparce, so I would look to see if you can find a real OEM service book on it that shows all of the wiring. Attached is what the info we have shows for the power train and it's missing a few things but it should help some.
May 30, 2022 at 3:13 PM
