I am at a loss here, I shut the truck off one day and came back out approximately 10 minutes later and it would not start. Engine turns over at ease but I quickly found that it would not fire. I traced wires and checked everything out. I put an ignition control module, coil, crankshaft position sensor, and distributor on it to try and get an idea on what it could be. I ended up towing the truck home and ruled it to be the ECU/PCM after finding that the signal wire doing into the Ignition control Module was not getting a 5v pulse when cranking the engine. I have checked all wires to and from the ICM, Coil, and Crankshaft position sensor and this signal wire was the only issue found.
I ordered a new ECU/PCM flashed and programmed to the VIN. When it came in I plugged it in. Started the ignition code relearn sequence and the truck started ran and idled great for about 30 minutes. I shut the truck down and figured it was a done deal. Went out the next day started the truck right up drove down to the garage behind the house and after exiting the truck for about 45 seconds it shut off on its own. Went back to start it up and back to square one no signal from the signal wire going to the coil. I need help!
FYI, I checked all fuses and checked for codes(none) no lights. Security light does as it should. Nothing is standing out to me but something is tripping this pcm or something. I appreciate any help at all! I feel as if I have hit a wall and don’t know which route to go now.
Jul 29, 2021 at 12:42 PM
