Truck shut off while idling, upon trying to restart, it coughed and idled very roughly and shut off again. Now it does not fire at all.
Checked fuel pump pressure at rail and is 60 PSI. After discovering no spark, began checking the ignition system. First step was checking ICM voltage on the pink wire, but it has 1.5vdc, regardless of key position. Does this point directly to an ignition switch issue? Based on how it shut off and reacted, I would have thought coil. Suggestions?
Jul 12, 2021 at 9:50 AM
