Started off with the Motorcraft alt and tried to switch to the Delco 10si. Started vehicle to test alternator and pulled the battery terminal loose and it shut off. Looked everything over and it all looked good. Had the key on for a bit, noticed the relay at the bottom of my fuse box was warm to the touch. Shut off the key for a while.started it up after I had double checked everything and it ran for about four minutes and shut off. Now no spark to the distributor. Have a Accel 59101 distributor and Accel super stock coil and a six wire ignition module. Guessing it is a 1978 ignition module. I checked the connections and nothing. Still have not done the alternator conversion as I was worried I burned up something. I have a meter and the test light. Show voltage on both sides of coil and both sides of resistor. And the starter relay one one side. My distributor is sealed so I do not want to break the seal on it. Not sure where to start? I can send some pictures tomorrow.
Jul 8, 2018 at 8:08 PM
