Will not start, no spark
2000 CHEVROLET SONIC
90,000 MILES • 6.0L • V8 • 2WD • AUTOMATIC
VEGASJIM
The truck has a 6.0, had a bad bearing in it, so bought a 2004 6.0 and replaced the engine. We kept the original intake, wire harness, PCM. Now it will not start. Have fuel, power to the coils, but no spark. Changed the crank and cam sensors and checked the grounds. All see good. All connections are hooked up. No issue with the security system, we checked it too. Any suggestions???
Apr 3, 2020 at 2:47 PM
I believe this is a 2500 chevy truck. If I am not correct, let me know.
If there is no spark, I have a feeling it is the ground wire for the coils. There is one common ground that all coils are spliced into. The wire should be grounded on the driver's side of the engine toward the front, on the engine block. This is a common problem when spark is lost. The wire will be black in color and it goes to an eyelet type connector that then bolts to the block.
Now, there is a chance it wasn't connected when you replaced the engine or was damaged. I don't know if you are using the same coils or what was done. But, when you locate the ground, if it is connected don't assume it is good. They corrode, come loose at the crimp, and so on. The easiest way to check is by simply running a new ground to the wire itself and see if you get spark.
Let me know what you find. Also, I said the ground was toward the front of the engine block, driver's side. I am saying that from memory. It could be further back on the block, but it is on the left side.
Apr 3, 2020 at 5:57 PM
VEGASJIM
Joe,
You are exactly right. Although it was connected, it wasn't a clean connection. We disconnected it, cleaned the connections and put it back on. Truck fired right up!
Thank you for taking the time to respond, it is much appreciated!
Apr 5, 2020 at 9:08 AM
You are very welcome. I had a feeling that was the issue. Regardless, I'm glad you got it running. Take care and feel free to come back anytime.
Apr 5, 2020 at 5:40 PM
