Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Chevrolet
Aveo
Engine
Symptoms
Stall While Driving
Engine was running then it shut off
2008 CHEVROLET AVEO
108 MILES • 1.6L • 4 CYL • 2WD • MANUAL
ERIC LEIKER
MEMBER
1 POST
FOLLOW
Car was running then shut off. Will turn over, has gas, but no spark. Replaced coil pak and crank sensor.
May 4, 2018 at 1:11 AM
CERTIFIED EXPERT
It sounds like the main power relay is not working. Here is a guide to help you test the relay:
Here are the fuse panel and relay locations for your car. Check out the diagrams (below).
May 6, 2018 at 12:58 PM
