No spark
1999 TOYOTA 4RUNNER
200,000 MILES • 3.4L • V6 • 2WD • AUTOMATIC
NORUN4RUNNER
Replaced RCU with an ECU that has been flashed so that the transponder is disabled and the center ECU plug is not plugged in. I have replaced coils, wires, plugs, igniter and crankshaft positioning sensor still no spark. Checked with test light and everything gets power but no spark past coil.
Sep 27, 2018 at 5:27 AM
These cars had a problem with the ignition ignitor but to be sure lets check for power and ground for the PCM. Here is a guide to help you confirm the issue and the engine wiring diagrams so you can see how the system works:
If everything looks good I would replace the igniter.
Sep 29, 2018 at 11:53 AM
