car randomly wouldn’t start No spark?
2009 BUICK ALLURE
210,000 MILES • 3.8L • V8 • AUTOMATIC
NIHAL
  • 15 POSTS
A few months ago, the car randomly wouldn’t start. It was a crank no start. I looked online and checked the fuel pump which was fine and had a no spark issue. I replaced the spark plugs, and it was the same. Then I replaced the coils which didn’t solve the issue and after that I replaced the control module which fixed the issue. The car worked for about 2 weeks before the same thing happened. The fuel pump is fine and I’m not getting any spark. I replaced the module and this time it didn’t solve the issue. The module is getting power but isn’t giving power to the spark plugs. I took apart the fuse box and all the wires and ground connection seemed to be fine. All the fuses and relay are also fine. What could my issue be?
Dec 26, 2024 at 1:37 PM
Have you checked the crankshaft position sensor? If it has failed, it will prevent spark to the plugs.
First, if you have a live data scan tool, check for an RPM signal when cranking the engine. If you don't have a scanner, see if the tachometer moves a little when cranking.
If there is no signal, replace the crankshaft position sensor. I attached the directions below specific to your vehicle.
Check for a signal and let me know what you find.
See pics below.
Dec 26, 2024 at 10:21 PM
NIHAL
  • 15 POSTS
I used a obd2 scanner and it doesn’t show me any codes for crankshaft position sensor, but I will try your method. Thank you
Dec 27, 2024 at 9:53 AM
The sensor can fail and not set a code. Because a crankshaft position sensor is related to engine speed, when it fails, it may not trigger a CEL light. This is because some things can stop the crankshaft position sensor's signal that will have nothing to do with the sensor going bad, such as running out of gas or stalling the engine when letting the clutch pedal out too quickly.
Take a look through this link:
Let me know your thoughts and what you find.
Dec 28, 2024 at 8:54 PM
NIHAL
  • 15 POSTS
I took the crankshaft sensor out and I tested it using a multimeter and it was fine but I took the camshaft sensor, and it turned out to be bad so I ordered one and should be here in a few days and hopefully fixes the issue. Thank you for your help.
Dec 28, 2024 at 9:10 PM
Thanks for the update. If that doesn't resolve the issue and you have a live data scan tool, check to see if there is an RPM signal when cranking the engine.
I suggest checking because loss of ignition spark is usually the result (not always) of a failed crankshaft position sensor.
Let me know how things work out for you.
Dec 28, 2024 at 9:46 PM
NIHAL
  • 15 POSTS
Hi Joe, the camshaft position sensor didn’t do the trick, and I checked the crankshaft position sensor using a multi meter and it is working. Next, I will try and replace the electrical part of the ignition switch because I heard that may solve it.
Jan 5, 2025 at 3:59 PM
I'm not familiar with an issue with the ignition switch. Anything is possible.
I attached a technical service bulletin (TSB) below for your review. It is related to the use of non-OEM ignition parts.
Last, I need confirmation that there is power to the coils. See the last pic below. Check the fuse with the ignition key in the run position. If it has power, go to the module and check if power is present at the pink wire.
See pics below.
Jan 5, 2025 at 9:52 PM
NIHAL
  • 15 POSTS
Hi Joe, I checked the fuse, and it is good and there is power going to the pink wire. I used a test pen to check it. But when I put the test pen on the module there is no power. Thanks for your help.
Jan 5, 2025 at 9:58 PM
If you have power at the fuse, the wire must be broken between the fuse and the module. Power comes from the powertrain relay in the under-hood fuse box and to the fuse you checked. If that has power, then the relay is working.
If you have power out from the fuse, it goes directly to the control module. If you can, disconnect both sides of that power supply and check it for continuity. We must be missing something simple.
See pic below (ignore the first pic. I can't delete it)
Jan 5, 2025 at 11:29 PM
NIHAL
  • 15 POSTS
Hi Joe, sorry for the late reply, I’ve been a little busy. The wire can’t be broken since the module is getting power from the fuse box. But the spark plugs are not getting any power. I’m going to try and put the old module in because of what you said about non OEM parts not working and see if that solves the issue. If not, then I will get a ignition switch because I saw some videos online saying it could be that. Hopefully the car will get fixed soon. This is 1 hour after I posted the first reply and I’m editing it now. I worked on the car and noticed that when I plugged the ignition control module that I could hear and see the spark on the coils and that would only happen sometimes. I also noticed that when it did the spark the RPMs went up to 3k and the fuel pump turned on and off. I don’t know what that means please let me know.
Jan 12, 2025 at 11:38 AM
So to recap, you replaced the crankshaft sensor and the ignition control module? I crankshaft sensor can test good with a multimeter but fail during the engine operations. Also, no trouble codes? When the engine stalls you are certain there is no spark correct?
Jan 15, 2025 at 9:42 AM
NIHAL
  • 15 POSTS
No I am going to replace the crankshaft position sensor but replaced the camshaft position sensor and also replaced the ignition control module. I also replaced the spark plugs as well as the coils. The engine cranks but doesn’t start and there is no spark. The spark only happens when I unplug the control module and plug it back in. As I plug it in I can physically see and hear the current on the module. But when I go to start the car, the spark stops which causes it to not start.
Jan 18, 2025 at 4:27 PM
When you lose spark, check to see if there is an RPM signal. You can do this with a live data scan tool or watch the tachometer to see if it moves a little.
What you described surely sounds like a faulty crankshaft position sensor. Take a look through this link. Let me know if you feel it mirrors what you are experiencing.
Let us know.
Jan 18, 2025 at 6:53 PM
NIHAL
  • 15 POSTS
I replaced the crankshaft position sensor, and the car still does the same thing. I am going to try and replace the ignition switch to see because that’s the last thing I can think of. Please let me know if it can be something else.
Jan 26, 2025 at 2:43 PM
This is a tough one. However, you mentioned there is no power to the module when this happens, but you still have power at the fuse. That, in my mind, indicates it isn't the switch, but anything is possible. I suspect a broken or damaged connection between the fuse and the module. Let me know your thoughts.
Jan 27, 2025 at 6:20 PM
NIHAL
  • 15 POSTS
No there is power to the module, but the module isn’t giving power to the spark plugs. I don’t know what the case could be.
Jan 27, 2025 at 6:54 PM
If you aren't getting power to the module, is won't work. We need to try jumping power to the module to see if that allows it to start in these conditions. Also, the next question would be where is the power being lost?
Jan 27, 2025 at 7:45 PM
NIHAL
  • 15 POSTS
The module is getting power and all wires are intact.
Jan 27, 2025 at 7:46 PM
Sorry about that. I misread your last post.
Make sure the ICM is grounded. At the connector, there is a black wire with a white tracer. That grounds to the front top of the engine. Make sure it is a solid chassis ground.
Next, there will be a red wire with a black tracer. That is a signal ground from the PCM. Confirm that is producing ground. when cranking.
The white wire is from the PCM. It is the ignition timing control signal. That should be producing a signal as well.
If these things are not present, I have a feeling the PCM is faulty.
See pics below.
Jan 27, 2025 at 8:02 PM
NIHAL
  • 15 POSTS
Okay, thank you. I will look into this tomorrow morning.
Jan 27, 2025 at 8:07 PM
JACOBANDNICKOLAS is one of our best! Please le us know what you find.
Jan 28, 2025 at 9:41 AM
NIHAL
  • 15 POSTS
Jan 31, 2025 at 11:45 AM
NIHAL
  • 15 POSTS
Jan 31, 2025 at 11:48 AM
NIHAL
  • 15 POSTS
I just checked and the ground from the black wire is solid but the ground and power from the pcm was not producing anything when I was cranking the engine. This has to mean that the PCM is faulty. I checked this by using a test pen light and stripping the wires from the middle to where the test pen could fit and there was no light.
Jan 31, 2025 at 11:50 AM
Yep, I have seen the PCM cause this issue, you can get a preprogrammed unit by searching Google or Ebay. But, I have also seen a shorted coil shut down the PCM ignition coil drivers as well. I know you replaced the module but did that include the coils as well? Here is how to change out the PCM. Check out the images (below). Please let us know what happens.
Feb 1, 2025 at 9:54 AM
NIHAL
  • 15 POSTS
Turns out that it was the crankshaft position sensor but when I was reconnecting the module to the harness, one of the pins broke which caused it to not start. I put a different module and the car finally started. Thank you for all you help.
Feb 1, 2025 at 1:59 PM
Glad you could get it fixed, thanks for letting us know. Please use 2CarPros anytime we are here to help.
Feb 2, 2025 at 8:51 AM
